Fog light harnesses
Old Jun 25, 2012 | 08:25 PM
Dragon05's Avatar
Dragon05
Default Fog light harnesses
Ok, my 05 was a base ST model with no foglights. I found an SLT bumper cover and foglights. Now, I thought I read that the harnesses were already there and just needed connecting. I had the headlights and bumper cover off today and cannot find any harnesses. Anyone?
Old Jun 25, 2012 | 08:28 PM
cheeseburger's Avatar
cheeseburger
i just went to the junk yard got the plugs an wired them up with a relay. the St's dont have the harness from the factory. Sorry.
Old Jun 25, 2012 | 09:25 PM
Dragon05's Avatar
Dragon05
Dammit.....then maybe I'll just wire some of my blue LEDs into it instead. Maybe a group of 3 in each one? Just for show, not go, since the blue is illegal when moving.
Old Jun 25, 2012 | 09:33 PM
Reject's Avatar
Reject
my 05 ST had the Factory Fog Harness, Fuses and All Relays installed.
I only needed the Fogs Housings and Headlight Switch, then get the Dealer to activate them.
It was pretty easy to spot them, they were coiled up.
You can see one here, it is next to the Window Washer Reservoir. It still coiled (I installed a higher gauge wire extension)
Then in this one you can see it infront of the drivers side tire.
Old Jun 25, 2012 | 11:07 PM
Dragon05's Avatar
Dragon05
Thanks Reject, I'll give it another look. I already have an OEM switch, (check ebay) and if the harnesses are there, I'll hit the dealer to activate.
Old Jun 26, 2012 | 11:04 AM
donkeypunch's Avatar
donkeypunch
King Jackass
I don't know if it was different in 06...but I don't have the harness. I bought the lamp assemblies off of amazon, picked up two pigtail connectors at advance auto parts (9005 or 9006, cant remember) and wired it myself.
Old Jun 26, 2012 | 01:31 PM
durapu's Avatar
durapu
9005 is the simular pigtail connector
