day two
Old Jul 25, 2012 | 05:48 PM
norma jean's Avatar
norma jean
Default day two
how do you get the front strut assy off? the nut wont go thro the hole at the bottom of the strut to the knuckle
help
Old Jul 25, 2012 | 06:04 PM
Holbrook.Jeremy's Avatar
Holbrook.Jeremy
The bolt won't come out? You can try spraying pb plaster and hitting the bolt with a hammer to knock it out, be careful to not mushroom the end of the bolt or you'll be in a world of hurt. If that doesn't work put it all back together and order 2 lower strut bushings napa part number NCP2673738.
Old Jul 25, 2012 | 06:08 PM
norma jean's Avatar
norma jean
hammer isnt doing it, the rubber in the middle is holding it
Old Jul 25, 2012 | 07:18 PM
That is the pain in the a$s about the whole job...
Old Jul 25, 2012 | 07:30 PM
Holbrook.Jeremy
I had the same thing happen and I put the side back together and ordered the bushingl. I'm planning on melting the bushing, removing the bolt, replacing the strut, and putting it all back together again with new bushings.
Old Jul 25, 2012 | 07:58 PM
Alfons's Avatar
Alfons
Before you destroy that bushing like I did, make sure you actually get the correct bushing. Even through the dealer, I was unable to find the correct bushing. There was a part number for it but all you got was the large bushing that's used on the ends of the lower control arm. I eventually changed the control arms because I got a good deal from the dealership since their part numbers were all screwed up.
I did hear that someone on this site actually found the right bushing, but since it wasn't confirmed, I'd still want to make sure before melting the old one.
Old Jul 25, 2012 | 08:07 PM
rebel4055's Avatar
rebel4055
Yeah that bolt won't come out without fire. I can spin mine with the nut off and hit it to my hearts content.
Old Jul 25, 2012 | 08:09 PM
norma jean's Avatar
norma jean
i gave the F*CK up, real pissed about it, that strut bottom bolt got HALF way out, then gave up, cuz it was starting to mushroom real bad. then put everything back to gether and took off the sway bar. and had my dad being a negative nancy the WHOLE sitting next to be on a 5 gal bucket. now im saving money to get the struts done at the shop and have them put the leveling kit on
and i pretty much need a new front end, every bushing is SHOT
Old Jul 25, 2012 | 08:51 PM
JoeyDMG's Avatar
JoeyDMG
I think when I attempted mine, I got the bolt out by using an electric impact wrench and hammer. I also had to let the entire arm be unsupported despite what the manual said. In the end I gave up too since the arm didn't drop so don't feel bad.
Old Jul 25, 2012 | 08:52 PM
BAdassR/T's Avatar
BAdassR/T
Pb blaster, torch and BFH with something to drive that bolt out with. Took me
Several hours to do both sizes but in the end I got them done
