Drive shaft
Old Aug 17, 2012 | 05:58 PM
Nick Asher's Avatar
Nick Asher
Default Drive shaft
I was told that my front drive shaft has a bad ball joint by the transfer case. Does anyone know the name of this part, and where I can get one. Maybe a video of someone replacing one?
Old Aug 17, 2012 | 07:27 PM
06Dak4.7Silver's Avatar
06Dak4.7Silver
You must mean a u-joint.. RockAuto.com has them in stock
Old Aug 17, 2012 | 07:30 PM
dimesismoneytoo's Avatar
dimesismoneytoo
Either that or a CV Joint.
Post some pictures up so you can recommend the right parts.
Old Aug 18, 2012 | 11:38 PM
Nick Asher's Avatar
Nick Asher
I have no cue what he was talking about. I was getting my transmission repaired and he told me is had ply in it.
Old Aug 18, 2012 | 11:42 PM
Nick Asher's Avatar
Nick Asher
He did say something like the universal joint. Is there any way I can figure out what is is?
Old Aug 19, 2012 | 12:19 PM
Alfons's Avatar
Alfons
Crawl under the truck and try to move the drive shaft up/down, back/forth and watch the joint at each end to see which one has play. You have one that's a standard U-joint (single cardan style) and one that's a Constant Velocity (CV) joint. If you're not going to change it yourself, the garage you take it to for a quote will tell you which one it is & how much for parts & labor.
Old Aug 19, 2012 | 04:26 PM
dimesismoneytoo
If it is in fact the CV joint that comes out of the Transfer case, it's fairly simple to replace. The part will run you roughly $115. I just replaced one on my truck.
