Play in steering wheel finally fixed.
Old Aug 22, 2012 | 07:33 PM
phil74501's Avatar
phil74501
Default Play in steering wheel finally fixed.
For about 2 or 3 years I've had a problem with some play in the steering wheel. I've had things checked nothing. Steering gear box was fine, toe in helped but didn't solve it. Finally I came across a post on a webpage, tried it, worked. Tightened the pinch bolt on the steering shaft located above the brake pedal. It took a crescent wrench and some elbow grease to crank it down, but it worked. Least I hope that fixed it. We'll see. I've read some posts on here before from people that had the same problem and couldn't figure it out. Hope this helps someone.
Old Aug 22, 2012 | 09:05 PM
Eimer123's Avatar
Eimer123
Glad to hear you might have found your issue. I have been chasing a steering issue for over 4 years now, and have just given up on it.
Old Aug 22, 2012 | 09:53 PM
phil74501's Avatar
phil74501
You sound like me. I had given up on it as well. I just happen to stumble across that looking at something else.
Old Aug 22, 2012 | 10:51 PM
Eimer123's Avatar
Eimer123
I will check that connection, but I do not think I have the same symptoms.
