check engine light running rough
Old Sep 10, 2012 | 07:41 AM
Red3G06Fwd's Avatar
Red3G06Fwd
Default check engine light running rough
went on a long trip over the weekend, and on the way home i had a check engine light come on and the trucks rpms would jump up and down with cruise control on, when id slow down between 45-55 if felt like a hard down shift jarring the truck. about 20 miles from home i stopped to the store to fuel up started the truck the check light was off and seemed to be running fine but when i got up to speed to put cruise control on it wouldnt work. and now this morning i leave for work the light comes back on and cruise control started working again and it started running rough again any help or ideas? thanks in advance
Old Sep 10, 2012 | 12:04 PM
JoeyDMG's Avatar
JoeyDMG
You try going to an auto parts store that will pull the codes for free? Autozone will do it... I'd bet it's still holding in the computer since you haven't reset it.
Old Sep 10, 2012 | 12:36 PM
Have it checked for codes. Thats the only way to really troubleshoot it. We could all give yuou ideas but pulling the codes is the best way to find out whats wrong.
Old Sep 11, 2012 | 01:59 PM
DodgeCares's Avatar
DodgeCares
Red,
I agree about getting the code(s). Also, what year and motor do you have?
Old Sep 12, 2012 | 07:25 AM
Red3G06Fwd's Avatar
Red3G06Fwd
Sorry took so long to respond my email wasnt showing up right away. But I wa looking around the motor and noticed the previous owner had zip tied the tps sensor wires to I'm assuming was the aluminum ac line and I guess over time it caused the sensor to actually crack where the wires plug in at. So problem solved. Thanks for help and advice
Old Sep 17, 2012 | 10:07 AM
Red3G06Fwd's Avatar
Red3G06Fwd
the trucks running fine now but cruise still doesnt work
Old Sep 17, 2012 | 10:56 AM
superdak05's Avatar
superdak05
you may have to disconnect the neg battery terminal for a few, then reinstall cable, if that doesnt work, check the fuses, you may have blown one
