Rear diff leak at the Driveshaft
Old Sep 22, 2012 | 05:10 PM
brifan2's Avatar
brifan2
Default Rear diff leak at the Driveshaft
The other day I noticed that there was some diff fluid coming from the plug in the rear diff on my 2005 Dodge Dakota 4.7 SLT. When i was underneath cleaning up the oil I noticed dirty oil around the front of the diff and a little on the end of the drive shaft. The oil was dry and I didn't notice any wet spots. What might the problem be and what would the cost be to get it fixed? Thanks
Old Sep 22, 2012 | 08:08 PM
Alfons's Avatar
Alfons
It could be a very slow leak through the pinion seal, mine has that also - no drips, no real wet area, just an oily stain in the dirt around the shaft. I just check the level every 6 months or so to make sure it's good & have seen no appreciable loss (using my finger as a dipstick through the fill hole).
Old Sep 22, 2012 | 11:52 PM
erau's Avatar
erau
Ditto.
Old Sep 23, 2012 | 10:52 AM
MonkeyWrench4000's Avatar
MonkeyWrench4000
Mine is doing this too. It also never drips, just seeps enough to stain the housing. I actually had it replaced once (the seal) under warranty. 2 years later the new one has a slow seep. If its not lowering the level, its not worth fixing ASAP.
Old Sep 24, 2012 | 12:18 AM
brifan2's Avatar
brifan2
Checked the level and it is good. Thanks for the help
