2006 Dodge CEL with Low Temp Reading
Soooo... I got a little lazy and while the 2006 4.7L Dakota was in for a Tranny Service...I had them flush and fill the Coolant. The original collant had 112K miles on it so I figured I'd get it done rather than do it myself.
A week goes by and all seems well...then this morning I fire up the truck to go to work. It s in the 30's when I leave at 0500. About 3 miles down the highway the Check Engine Light BINGS. I look at the guages and notice that the Coolant Temp guage is down to just over WARM...and the heater isn't blowing as hot as normal. I pull off at the next exit and look the engine over...no leaks...and the top hose is warm.
I decide to drive back home and take the 2000 Durango into work. On the way home....the heater heats to normal hot...but the guage does not budge. I get home...check the engine again...the top hose is hot...bottom hose is cold and the radiator isn't very warm at all.
I am thinking the T-Stat is stuck closed....but why the heater blows hot and the Temp Guage shows LOW is confusing me. Anyone one else have a similar issue? What was the problem.
Thanks.
JJ
Thanks.
JJ
Thanks superdak05 will try that.... of course the question is....shouldn't they have done that at the dealership? I called them but they sure weren't to suggestive as to what could be causing it.
I had the wife pull the code on it (funny side story there) and its throwing a P0128.
will post update this pm.
JJ
JJ
