Spark Plugs
Old Jan 26, 2013 | 07:24 PM
Reject's Avatar
Reject
I run Autolite 3923 in my 05 V6, no issues, helped smooth the idle some aswell
Old Jan 27, 2013 | 08:08 PM
wingman_214's Avatar
wingman_214
I highly recommend NGK V-Power plugs. OEM champions are decent as well.
Old Jan 29, 2013 | 07:53 PM
whitecotton03's Avatar
whitecotton03
so i got a question... ive saw if you get the spark plugs gapped at .35 rather than .40 it makes the engines run better and stops some of that vibration at idle or park
Old Jan 30, 2013 | 06:52 PM
whitecotton03
Old Jan 30, 2013 | 11:00 PM
jasonw's Avatar
jasonw
Site Moderator
I have never heard of that before, but you can try it out if you like. Worst case scenario, you regap the plugs back to recommended.
Old Jan 31, 2013 | 07:52 AM
northgator8's Avatar
northgator8
Jason, you obviously don't work in risk management . . . LOL
Worst-case scenario is that when re-installing after the second re-gap you cross-thread one of the rear plugs, screw up the threads, have to drill out the hole, tap and find the right thread-repair kit and install it.
I could go on, but done correctly, you are right!
Old Jan 31, 2013 | 11:31 AM
whitecotton03
so are you sayin if i install .35 it will run smoother??
Old Jan 31, 2013 | 06:46 PM
jasonw's Avatar
jasonw
Site Moderator
Haha. You got me there. OK, assuming the removal process and reinstall processes go smoothly, what I stated was true.
Old Feb 10, 2013 | 02:12 AM
Ronius_MAXimus's Avatar
Ronius_MAXimus
Just installed some NGK Iridiums (9441) today in my V6 07 Dakota. I have no idea if the spark plugs have ever been charged but the truck just hit 60,000 miles, and the spark plugs I replaced were NGK-R's. They looked pretty good when I took them out, so i'm assuming they might not be the originals. Anyways, what a difference! I noticed that the truck is less sluggish and am glad I did it. For me, the hardest plug to get to was the the on the passenger's side, closest to the firewall. It was right there with the transmission oil dip stick and I was worried I would strip the threads because of the angle but I just took my time.
