Getting the Shaft?!
Old May 13, 2013 | 10:58 AM
donkeypunch's Avatar
donkeypunch
King Jackass
Originally Posted by lghtngblt02
So.....1500 miles later and the passenger side outer tie rod is doing what the drivers side was doing...ARGHHH...
Yah, unt you should have replaced bose of zehm! You suck again vis your Zimas unt your Shmearnoff Ices. Unt duesen duesen. Lol.
Old May 15, 2013 | 11:50 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
lol, yeah for sure! All done, replace it in 20 minutes yesterday! No sometime in the future I'll get an alignment or have it checked, I am going to say its on, only because I have no pulling in either direction and the steering wheel is straight
Old May 15, 2013 | 06:46 PM
italiandominator's Avatar
italiandominator
I had a steering issue recently. Had to replace both tie rod ends. Had never done it before and after doing research, it ended up being pretty easy.
I was also having a similar issue with my steering. Thought it was power steering pump. Turned out it was my intermediate steering shaft. Part was a lil pricey, but the install was super easy. Just two bolts hold it in.
