Why is there a ground strap from the exhaust to the frame?
Old Apr 9, 2013 | 06:04 AM
larryhagmansliver's Avatar
larryhagmansliver
Default Why is there a ground strap from the exhaust to the frame?
....and do I need to put it back?
I just finished installing an aftermarket cat-back exhaust system and I noticed the strap bolted to the front of the stock muffler. What is it's purpose?
Old Apr 9, 2013 | 09:25 AM
Alfons's Avatar
Alfons
Exhaust gas motion through the exhaust system can create a lot of static electricity. This needs to bleed off unless you don't mind the occasional zap that could get into some of your sensitive digital circuitry in the wrong place. I would keep the strap in front of any joint in the exhaust system for best bleed-off performance. If all the joints are welded, the strap position won't matter.
