cb antennas with tonneau cover?
Old May 8, 2013 | 11:13 AM
ixl4's Avatar
ixl4
Default cb antennas with tonneau cover?
Hey I have beein googling, looking at different mounts, reading here and still not sure what to do.
I've got a soft tonneau cover on my truck and would like to mount a cb antenna. ideally, id like to do a dual antenna setup, but not sure where to mount.
I thought about mounting to the bed between the cabin and bed itself but its too narrow for a mount to fit in there. I ran out of ideas, short of mounting to the bed and making 2 small holes in the cover itself for the antennas to stick out through... but it would only be a matter of time before the holes ripped into bigger ones.
Old May 8, 2013 | 04:59 PM
Reject's Avatar
Reject
You could try to make 2 Flat brackets that come out under then Tonneau out the sides.
something like this
Old May 8, 2013 | 08:02 PM
pyrofossil's Avatar
pyrofossil
One thing you can try is putting a hole grommet. So you understand hears a link. I know I have also seen them mounted on the bumper, or between you cab and the bed. You may have to bend the antenna a bit, but should still work fine.
http://www.ebay.com/itm/HAND-PRESS-PORTABLE-GROMMET-MACHINE-HOLE-PUNCH-TOOL-w-500-Size-3-GROMMETS-/181067215015?pt=LH_DefaultDomain_0&var=&hash=item2a287270a7
3" Leveling kit- Rancho's All around- 265/75R16 BFG Rugged Terrains- Custom Short Ram Intake- Flowmaster 40 w/ custom 3" stacks- Black housing headlights 6k HID- Custom HarleyDavidson Shifter -
