AC low pressure switch location 2005 Dakota 3.7L
Hi Guys,
Any body Knows the LOCATION of the ac low pressure switch for the dakota?
My ac clutch stop engaging and when i hook up gauge accumilator service port = 0 pressure.. I want to recharge refrigerant and I need to short the low pressure switch connector to engage the clutch.. First time it happen..
Please help... Thank you..
The clutch should engage when you add refrigerant. I've never had to short mine out even after opening the system to replace a component. Just hook up your can and start filling, the compressor will engage when the pressure increases due to adding refrigerant.
I was succesfull adding refrigerant.. After about 3 minutes of adding refrigerant(AC Pro Professional) the charging hose still hook up, I started the car and turn on ac full blast. The compressor clutch kick in and i was able to finish charging the AC. I hope the charge will hold, Its cold now in the truck and i am happy..
Thank you again..
Thank you again..
