Quick Tip When Swapping Spark Plugs
Old May 20, 2013 | 01:26 AM
italiandominator's Avatar
italiandominator
Default Quick Tip When Swapping Spark Plugs
Hey y'all, just a quick tip when swapping out your spark plugs.
They say you should only change one spark plug at a time so you don't mix up which coil pack goes where, which is a good idea, but if you're like me...you probably want to just take them all off at once, so...to never confuse which coil pack goes where try labeling them, like this for example.
Old May 20, 2013 | 07:56 AM
I just do one at a time. That way I know which one goes where.
Old May 22, 2013 | 03:43 PM
italiandominator
I hear you there, I just prefer to lube everything all together, use the same socket to take everything off, etc etc...I just don't like having to swap my sockets every other minute. To each their own, thousand ways to skin a cat.
Old May 22, 2013 | 11:40 PM
moe7404's Avatar
moe7404
sure is different from many years ago.
Old May 23, 2013 | 12:06 AM
italiandominator
In reference to what exactly?
Old May 25, 2013 | 10:47 PM
moe7404's Avatar
moe7404
what are all the letters for? in my day it was one plug one cyl, one wire. what IS a coil pack? as you tell iam straight OLD SCHOOL. really i depicted this type of ignition 20 years ago.
Old May 28, 2013 | 12:35 AM
italiandominator
The letters are to reference orientation, R = Rear and F = Front of the vehicle. Not sure exactly the purpose of the coil pack, but apparently it is what connects the ignition wire to the spark plug.
Old Jun 3, 2013 | 05:29 PM
sawfish's Avatar
sawfish
I just took a paint marker, and marked the number of each cylinder on its corresponding coil.
Old Jun 3, 2013 | 11:37 PM
italiandominator
Upon closer inspection when I took her apart, each coil wiring connector was actually labeled from the factory...who woulda thought? Derrrrr
Old Jun 4, 2013 | 10:37 AM
Tygarys's Avatar
Tygarys
The coil packs amplify the electric charge to the spark plug to a level that will ignite the fuel. This used to be done with just one coil and a distributor, but with computers separate coils for each cylinder give much better control, power, and mpgs.
