2007, front passenger window will not go down.
Old Jul 6, 2013 | 11:24 PM
Cali10's Avatar
Cali10
Default 2007, front passenger window will not go down.
No prior issues. Let the truck sit for about two months and when I came back, the front passenger window will not go down. The controls from both the drivers side and passengers side do nothing. No sounds, no movement. Other windows working normally.
Figured I could try and troubleshoot through this site first before I go get ripped off by the dealership.
Thanks.
Old Jul 7, 2013 | 09:15 AM
Alfons's Avatar
Alfons
Since all the other windows work, you can rule out a fuse, so beyond that you'll need to get access to the switch and the motor to see what's wrong. I'd start with the switch to see if there's power coming to the input of the switch - if not, the problem is in the wiring prior to the door or in the connector for that door, but if yes, then see if there's power on the output pins when you press the switch one way or the other. The next step if the switch & door connection are good, is to check the wires to the motor.
Old Jul 7, 2013 | 11:30 AM
The window may be stuck and tripping the braaker every time you press the switch if it sat for that long. Yet moving it by hand to see if you can break it loose.
