cut departure angles in the bed.
Old Aug 1, 2013 | 02:47 AM
Neil Hall's Avatar
Neil Hall
since I'm in engineering school, I may possibly look into some sorta long travel/lift kit/ overall better suspension setup this fall/winter. gotta start squeezing some power outta this little v8 motor also, throttle body, exhaust, SC tuner, E-fan, possibly some other stuff I'm forgetting.. all in due time though.
Old Aug 1, 2013 | 07:31 AM
northgator8's Avatar
northgator8
Originally Posted by projektdirtfab
Old pic....the spare and hitch are long gone.
Well, there you go!
Old Aug 1, 2013 | 03:42 PM
projektdirtfab's Avatar
projektdirtfab
Originally Posted by northgator8
Not working for me, unless you clean up the under bed mess that is the spare tire and bumper/hitch steel.
You are trying to clean up the look, but exposing stuff that, in my opinion, was meant to be hidden.
Just sayin'
and Its not so much cleaning up a look as it is gaining ground clearance as well as giving a little more room for rough landings lol...at least in my case for the reason I cut.
Old Aug 2, 2013 | 10:09 PM
Neil Hall's Avatar
Neil Hall
just began relocating the tanks today, mounted the washer fluid one upfront behind the plate. once i finish adding plate and lights you will not see it.
