auto trans filter kit and recommended fluid
" Also what is the recommended rear end oil for this truck. Dealership says they don't just drain it, they pull the housing off and re-fill. Any info on this subject?"
There is no drain plug, so they have to pull the housing if they're going to change oil.
I wouldn't worry about it. I ran my 1980 Ford for 25 years, over 200, 000 miles w/the same oil in the rear end and manual transmission.
Hey, Sleds: How do you know where to drill the pan, knowing you're going to install a drain plug? I'd hate to arbitrarily drill a hole only to find out that it was a bad place and damaged something for drilling in the blind.
