Seat Creaking
Old Aug 22, 2013 | 03:02 PM
James_thiessen83's Avatar
James_thiessen83
Default Seat Creaking
So I have a 2011 Dodge Dakota Crew cab. It only has 7200kms on it, and the last few days as I get in and out the seat makes a horrible creaking noise. It does not do it while I am driving, just as I enter and exit. It does it for everyone in my family, not just myself. I know I saw on the Ram forum that they had a crossbeam that had to be greased and wasnt from the factory. Just wondering if that is the case here too? Thanks for any help.
Old Aug 22, 2013 | 07:16 PM
James_thiessen83
Also now if I manually push down on the left side of the lower part of the seat I hear a popping noise. Any help still greatly appreciated.
Old Aug 22, 2013 | 07:29 PM
Deer Hunter's Avatar
Deer Hunter
If you have a power seat, raise it up and get in there with a flashlight and a mirror. That would be the best starting point. You might need another set of hands to push down on the seat while you are under there. The closer your eyes and ears are to the noise makes it easier to locate.
Old Aug 22, 2013 | 11:09 PM
James_thiessen83
It's just a manual seat. Not power just was curious if anyone's had this before and what they did
Old Aug 23, 2013 | 08:06 AM
northgator8's Avatar
northgator8
If it only has 7,200 kms on it, it has been sitting a lot. Something is rusted that shouldn't be (I know, nothing SHOULD be rusted). Some lube is in order, methinks.
Old Aug 23, 2013 | 09:14 AM
James_thiessen83
Ya I had a chance to play with it and the release to move it back and forth was causing the creaking. I have yet to lube it, but at least I found that part out.
Old Aug 25, 2013 | 01:27 AM
jasonw's Avatar
jasonw
Site Moderator
The seat belt will also cause a "creaking" noise. I found in my 2010, the female end of the seat belt can be pushed up against the center console, causing a leather-on-leather creak-type noise.
I was off-and-on thinking how to solve it, when I rode in a sibling's newer Ford Taurus one day. I saw how Ford had put small pads on the tops of the seat belts' female ends, to prevent the exact problem I was having.
I had some furniture pads (the sticky type you put on the bottom of chairs/tables/furniture to stop them from scratching hardwood floors) left over, and they did the trick perfectly.
Just another thing to think about if that noise still exists or comes back later.
