Digital Gauges
Old Aug 25, 2013 | 09:15 PM
ouv's Avatar
ouv
Default Digital Gauges
Do you guys think this will work in our truck?
http://www.ebay.com/itm/181153434654...84.m1438.l2649
Don't get too technical with this one guys, I just want to know if this could wire up to our Transmission.
Also, I'll be getting more:
-Tach
-Oil Pressue
-Boost
-Volt
-Water Temp
-Oil Temp
-Rich/Lean
They will be blue digital as well. I found a 07 Durango that has my cluster, and I was going to custom make out of a think aluminum or something strong that'll mount inside our dash, that'll have these in there, not all 8, but the good ones, then have some on the dash or not use all 8.
Now, you'll probably thinking, what about Odometer and Gears and CEL, well, I was going to cut those out of the aluminum sheet so they came through, like a stencil.
I know seeing a 2nd gen cummins dakota on YouTube with manual gauges.
WARNING, TURN DOWN VOLUME OR MUTE, VERY LOUD
Pause it at 35-36 seconds
Old Aug 25, 2013 | 09:41 PM
Jaded's Avatar
Jaded
Doesn't come with a sending unit. So either it is adaptable to the stock sender or you have to buy something separate but they're not giving enough info.
Old Aug 25, 2013 | 09:47 PM
ouv's Avatar
ouv
Maybe not that one, but these do
http://www.ebay.com/itm/141018727007...84.m1438.l2649
Only thing, there's no speedometer, I messaged the seller if they had one, or know where I can get one, no reply yet. I went on their site, no speed, so I'm not sure about that just yet. The one I posted was one of the closest ones to these. If I can find another set that has sending unit and speedometer, I'll go with those, but has to be blue
Old Aug 25, 2013 | 09:48 PM
ouv's Avatar
ouv
I also found these, but I don't think the sending unit comes with the Speedometer, but they do come with the other gauges
http://www.digital-speedos.co.uk/blu...auges-24-c.asp
