Quick questions about stock dodge dakota wheels?
Old Nov 5, 2013 | 01:12 AM
dieselpower32x's Avatar
dieselpower32x
Default Quick questions about stock dodge dakota wheels?
Im sure this has been asked a million times but I am having no luck finding it. I have an 06 4wd Dakota. I am looking for the offset and backspacing for the stock rims that come on it. They are 16" rims. Here is a picture of the rims on the truck. I am running 265/70 16's now on it and was told when I get my 2'' leveling kit on, I can run 285/70 16's without them rubbing or trimming anything? I want to get new rims also for it to and get some with a little bit of backspacing so they stick out a bit.
Old Nov 5, 2013 | 08:25 AM
It's in the FAQ section.
https://dodgeforum.com/forum/3rd-gen...07-wheels.html
Old Nov 5, 2013 | 08:29 AM
dakotaff's Avatar
dakotaff
Your stock wheels are 16" x 8", offset of 25.4mm (1"), backspace of 140mm (5.5").
You aren't going to run 285's without some major trimming. 265/75/16 may require some minor trimming, and definitely an easier tire to fit on your truck. Not sure who told you the 285's will fit.
The 285/70/16 will require more trimming than the 265/75/16 due to the extra width, as well as the slight height increase. Plus there is much more of a selection of tires in 265/75/16.
Read the thread posted above, as well as this one. Plus try to keep all of your tire questions in one thread.
We'll help you out the best that we can.
Believe us here, we've tried it all.
Old Nov 5, 2013 | 11:08 AM
dieselpower32x
My truck has 265/70 16's on it now and there is plenty of clearance now with those. And that is without the leveling kit on it yet.
As for a selection of tires, The tires I plan on using come in 285/70 16's.
Old Nov 5, 2013 | 11:35 AM
donkeypunch's Avatar
donkeypunch
King Jackass
Unless you are feeling huge, stick with 265/75/16s and a 2" leveling kit. This will require minor trimming on your factory alloys.
Here are some photos of my truck back in the day with 265/75/16s
Here are current pics with 285/75/16s
