Overhead Console Has Gone Dark
Old Nov 12, 2013 | 04:53 PM
jawfish1951's Avatar
jawfish1951
Default Overhead Console Has Gone Dark
I have not been able to determine which fuse matches up to my overhead console in my 2005 Dodge Quad Cab Dakota. Would anyone have access to a diagram so that I don't have to pull every fuse in the Power Distribution Center? Thank you.
Pam
Old Nov 12, 2013 | 08:21 PM
Should be a legend under the fuse cover top. There is a fuse panel inside the cabin as well as the underhood fuse box....plus, you can spot a bad fuse from the top. Your owners manual should also help.
Old Nov 13, 2013 | 01:18 PM
jawfish1951
Thank you jkeaton. I had already checked under the lid. The overhead console was not listed. I suppose because it may have been an extra add on. I was hoping to find someone who had a service manual as the owners manual does not cover any details on fuses.
Old Nov 13, 2013 | 03:25 PM
northgator8's Avatar
northgator8
You too can have the service manual! It is free to download by following the STICKY at the top of the forum!
Old Nov 13, 2013 | 06:40 PM
dakotaff's Avatar
dakotaff
Check fuse # 8 and # 14.
Welcome to DF.
