Changing spark plugs
Old Mar 23, 2014 | 01:07 PM
cncman40's Avatar
cncman40
Default Changing spark plugs
Does anybody have the procedure for changing plugs on an 06 with the 3.7l V6? Also what brand is best to use...That part of my owners manual is missing..Thanks
Old Mar 23, 2014 | 06:03 PM
dsimm87's Avatar
dsimm87
Just changed my 4.7L v8 today. Basically, you'll need to unplug the individual coil packs, unscrew and lift up the coil packs, then using a deep socket, remove the old plug and install the new one.
There's a tag under the hood on the passenger side that tells you the correct plug and gap you need.
Here's a vid of the v6 being done on a 3rd gen:
Old Mar 23, 2014 | 08:06 PM
Greatrack2012's Avatar
Greatrack2012
Just did mine in October, and I believe I used NGK'S. I was told to stay away from platinums.
Old Mar 24, 2014 | 06:59 PM
Yes. Stay away from the fancy plugs. Stay with copper core and change every 30k. 6 or 8 cylinder. They do not do well with the fancy rare metal plugs.
Old Mar 24, 2014 | 10:11 PM
jasonw's Avatar
jasonw
Site Moderator
My 4.7 is doing fine with Champion Iridium plugs, but then again, the 2008+ 4.7 V8s are used to the Nickel Yttrium (upper bank) and Iridiums (lower bank) from the factory.
Copper is better and cheaper, and if your engine didn't come with rare metal plugs from the factory, I wouldn't suggest using them.
