rear differential
Old Apr 23, 2014 | 10:22 AM
  #21
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Originally Posted by Tom A
BTW, changing just the differential does not require you to disturb the pinion, which is the most complicated part of gear setup.
Good info to know...
So no backlash adjustment should be needed? I've never torn into the rear diffs on these. Always have wanted to upgrade to an Auburn LSD.
Originally Posted by Lovinmydodge
just curious if anyone could help me determine my rear dif size ? I've been looking to get a limited slip, and changing the gear to say a 4.11 gear from the 3.55 as I have done a 3 inch lift, and used slightly larger tires, plus I just want alot more torque off the line as the 3.7 is a pig....
if someone could pm me what info u need i can give that info to u, thanks any help will be much app.
Count the number of bolts you have on the back cover... 10 = 8.25, 12 = 9.25
You'd be looking for 4.10 gears or 3.92 for an upgrade from the 3.55s
File Type: jpg
Old Apr 29, 2014 | 09:37 PM
  #22
rbrocchini's Avatar
rbrocchini
Default Spider gear replacement on LSD rear end
I need to have my spider gears in my 2008 Dodge Dakota, replaced. 9.25, 3.55. I was told by one shop it can be done, another shop said I would have to replace the whole carrier. He said the spider gears can not be replaced independently. Any help?
Thanks
Rick
