Run wires through Firewall?
Old May 4, 2014 | 04:38 PM
ouv's Avatar
ouv
Default Run wires through Firewall?
I installed some cheap LED bars on the grille, I still have more to put on, but I'd like to wire the 6 I have on it now, and have it in the cab right now. I can't seem to figure out where to wire the wires into the cab.
If anyone has any idea on this, I would appreciate it!
Thank you!
Old May 4, 2014 | 05:33 PM
Run the wires inside the drivers side front fender and through an existing grommet inside the door to get them inside the cab.
Old May 4, 2014 | 06:11 PM
ouv's Avatar
ouv
I didn't even think of that, thanks for that! I will think about doing that!
Old May 4, 2014 | 08:02 PM
Easiest way really, go through the hole in the engine compartment to the inside of the fender and through the door grommet. No drilling required.
Old May 5, 2014 | 04:37 PM
ouv's Avatar
ouv
Easiest way really, go through the hole in the engine compartment to the insode of the fender and through the door grommet. No drilling required.
Yeah, I checked it today after work, and looked under the dash. Thank you! Major help
