Window Motor or Regulator?
"drank beer, lubed it, then and played with it in the past"
I thought this was a 'family friendly' forum? Haha
But I have the same issue. My passenger rear window crapped out last year and I haven't had the ambition to try to figure out what the deal is. And both the driver's door and actual door switch are dead. So I doubt it's a switch problem.
Whom did you buy the whole assembly from? I'd prefer to do an entire swap as I agree its been binding some since new, I just never realized it.
I need help. I have a 07' Dakota. Passenger window will go down but NOT up. I have replaced driver door master & pass door switch with no luck. Then I replaced the motor also no luck. I have 12v in the down position AND up position and still only goes down and NOT up....please give me some input to fix this thing before I loose all my hair!! Thanks
