IAC problem?
Old Aug 28, 2017 | 06:52 PM
wingman7000's Avatar
wingman7000
Originally Posted by kenttt
After chasing this "doesn't want to slow down" problem for about three years I've finally resolved it. After replacing both the IAC and the TPS twice, once w/aftermarket and again w/Mopar parts, checked for vacum leaks, checked emissions system, had it into 2 different reputable shops that both said they could fix it and later said there was nothing wrong w/it, I figured it must be in programming, so I ordered a replacement ECM, installed it and problem is finally gone.
where did your order your pcm? I've had my 2 PCMs reprogrammed and I have the same problem with stalling at low speed. I'm going to try the TPS and IAC sensor replacement. I already tried cleaning the IAC sensor but still have the issue. It seems more prevalent in hot weather.
Old Aug 29, 2017 | 10:36 AM
kenttt's Avatar
kenttt
I bought it from All Computer Resources on ebay. If you need more info send me a PM.
