trailer brake controller
iv got an 05 dakota that did not come with a factory tow package so i dont have to quick connector under the dash so i was hoping that someone would be able to help me out and tell me what i have to do in order to install one not only in the cab but do i need to run wires all the way to the back of the truck or do i just tap into wires that are back there or what?
The adapter for tapping into the rear light will only get you a few of the connections you need. In addition to those you will have to run two wires from the front to the back. One to the battery with a circuit breaker and one to the brake controller. You will also need to run a wire from the brake controller to the battery with a circuit breaker and tap one into the output side of brake switch. The brake controller will have wiring instructions. The hardest part is running the wiring nicely from front to back, into engine compartment and into the cab. I was able to use an existing fire wall penetration with an existing grommet removing the grommet and using a metal hanger to fish it through. Took me awhile but I am meticulous and did a nice professional type install.
