Changed Spark Plugs
Old Sep 5, 2014 | 06:48 PM
dirtpoor's Avatar
dirtpoor
Default Changed Spark Plugs
New to the forum kind of new to Dodge Dakota. Had a first gen along time ago. Just bought a 2007 QC 2 wheel drive 4.7 flex fuel with a 100000 miles.
I changed the oil and filter and the spark plugs. Truck ran a lot better the plugs I pulled out where shot. Anyway I go for a ride to check it out and my cel comes on I check for the codes and it comes up with 744, 542, 335 I looked them up I forget what the 542, and the 335 are but the 744 torque converter clutch circuit intermittent. What would have caused this by just changing the plugs. Or was it just a coincidence. I did unplug the map and the tps. idk any kind of help would be great. Thanks in advance
Old Sep 6, 2014 | 08:21 AM
Jaded's Avatar
Jaded
Did you pinch any wiring using a jack or jack stands while changing the oil? Otherwise I'd say coincidence. Clear codes, reset and see if they come back.
Old Sep 6, 2014 | 10:05 AM
dirtpoor's Avatar
dirtpoor
For a 2 wheel drive it sets pretty high no need for a jack. I cleared the codes once. I will check some connections on the transmission. thanks for the reply
Old Sep 7, 2014 | 09:54 AM
Make sue the battery connections are clean, good and tight.
Old Sep 8, 2014 | 08:22 PM
dirtpoor's Avatar
dirtpoor
Ok Ive cleaned the battery connections and are clean and tight. I did that on sunday an so far the light has not came on. before it would come on after i drove it a couple times. I've drove it about a dozen times. So thanks for the great info.
Old Sep 10, 2014 | 05:48 PM
dirtpoor's Avatar
dirtpoor
Ok my check engine light is back on(744). Was searching the net and one thing to do is change the trans fluid and filters. The truck being used I don't know when the service was done. fluid looks good but I'll change it anyway
