2007 Dakota Remote Start ADD ONs...whats available
Old Dec 9, 2014 | 01:06 PM
mygurlsdakota07's Avatar
mygurlsdakota07
Default 2007 Dakota Remote Start ADD ONs...whats available
I wanted to get my wife a remote start system but lovely Chrysler (and everyone else) decided to make the key part of the remote lock fob. How in the hell do I find a system that can use my existing fob? Or what have other done. My problem is having 2 bulky fobs on her key ring which I couldn't stand myself. Since the key is built it, what are my options? Does Chrysler have a system for a truck this age? Thank you.
Old Dec 9, 2014 | 02:27 PM
pierrejoly's Avatar
pierrejoly
There are a few out there (i dont' know the exact part numbers) that allow you to use your current remote lock fob to use as start. you press the lock three times in quick succession or something like that. I'll check with my brother, He's done it to his caravan. Since everything is Canbus in both your truck and his van, the system might work out of the box. I'll get more info
Old Dec 9, 2014 | 02:49 PM
mygurlsdakota07
THank you I apprecaite that; that would be a nice system to keep the original fob clicker
Old Dec 11, 2014 | 10:02 PM
tmoore8828's Avatar
tmoore8828
Default Remote Start
This thread should give you the info you need to use your existing Fob for remote start.
https://dodgeforum.com/forum/3rd-gen...ote-start.html
Old Dec 12, 2014 | 02:52 PM
mygurlsdakota07
Thank you very much! Sounds easy enough to install myself. Just dropped by the remote starter and audio place $279 installed! Ouch, he probably was going to use this exact system and be done in 10 minutes!
Old Dec 13, 2014 | 08:46 PM
pierrejoly's Avatar
pierrejoly
It's super quick to install using the system above. That's the same one (from a different distributer) that my brother used.
Old Dec 13, 2014 | 11:10 PM
mygurlsdakota07
Thanks a lot for asking! Glad to know its the same one and he likes it! Bought one today; thanks again for the help.
Old Dec 14, 2014 | 12:41 AM
Reject's Avatar
Reject
I installed the Fortin in my work van (10' Caravan CV) its a very simple install, If I had factory FOBs id get one for the truck, Might still get it with a RF Remote kit. I had to buy the Flash Link to change the programing to what I wanted it for the van.
All you have todo is Unplug the Ignition at the Key, Plug in a T Connector, Plug back into ignition, plug into Evo-All then program using the directions.
Old Dec 22, 2014 | 11:31 AM
Corks's Avatar
Corks
Just make sure if you purchase the kit that it comes with updated firmware. I just purchsed one from ebay and had to drop another 50 to get the updater so it will work in my girlfriends 2009 ram
