Air bag wiring
Old Apr 20, 2015 | 07:21 PM
garryburrell's Avatar
garryburrell
Default Air bag wiring
Does anyone have a wiring diagram for the airbag system for a 2005 Dakota? My red airbag light is on in the dash. So I got a clock spring and installed it today ,but it didnt fix the problem. The passenger on off airbag switch works fine, or at least it test good.but it won't turn on the light between the air vents. so I am thanking the passenger seat switch is bad. What do you guys thank and is there any other things I could check?
Old Apr 20, 2015 | 08:36 PM
dakotaff's Avatar
dakotaff
Clink the link below my signature picture, there are wiring diagrams in the factory service manual.
Old Apr 21, 2015 | 07:25 AM
garryburrell
Thanks for the info. Do you know we're all of the parts are for the airbag system are?
Old Apr 21, 2015 | 08:03 PM
dakotaff's Avatar
dakotaff
I can't help out with the airbag parts. To figure out what the issue is, you will be better off using a SRS capable code reader, or finding someone who has one. If the airbag lights are on, your airbags may not function when they are supposed to.
