Park lights
Old Jun 11, 2015 | 01:39 PM
eric scott's Avatar
eric scott
Default Park lights
2005 Dakota park lights on left side don't work
I've changed both bulbs and put in a new switch where do I go from here
Old Jun 11, 2015 | 02:32 PM
pierrejoly's Avatar
pierrejoly
The park lights are shared with the signal lights up front. What happens when you put on your left turn signal? or your 4 way flashers?
Old Jun 12, 2015 | 10:20 AM
donkeypunch's Avatar
donkeypunch
King Jackass
Our trucks are fused for parking lights, left and right. Check your fuse.
Old Jun 12, 2015 | 11:01 AM
dakotaff's Avatar
dakotaff
And do the brake lights work?
Give us the most information and we'll give you our best educated guess, ...I mean advice.
Old Jun 14, 2015 | 09:08 PM
eric scott's Avatar
eric scott
didn't realize that will check that thnks
Old Jun 18, 2015 | 11:37 AM
superdak05's Avatar
superdak05
mine don't either, I checked everything, I traced the faulty part to the forward control module, the brass connectors inside have corrosion and split, I had to splice into the drivers side harness and run a jumper to the passenger side wiring harness
