2008 Dodge Dakota 3.7 engine
Old Jul 8, 2015 | 09:37 AM
rickluc's Avatar
rickluc
Default 2008 Dodge Dakota 3.7 engine
Where is the thermostat located on this truck? Any special points to change? Thanks
Old Jul 8, 2015 | 01:55 PM
pierrejoly's Avatar
pierrejoly
the thermostat is in the lower radiator hose. i would recommend replacing with a 180 degree thermostat. I did in mine when i had it and it made a difference. There is one available from NAPA. i don't have the number of the thermostat with me, but if you look in the FAQ thread, there is a listing in there. it's the same for the 3.7 as for the 4.7
Old Jul 9, 2015 | 07:56 AM
HammerZ71's Avatar
HammerZ71
I would hesitate to just toss a 180* thermostat in there. In some cases it's beneficial and in some cases it causes problems.
If you are bone stock you don't need a richer air/fuel ratio. Also if you live in a cool climate and don't do a lot of highway driving you could create oil sludge issues with a cooler thermostat.
Now if you have modified the vehicle, resulting in advanced timing and need to pour more fuel in the mix, then a cooler thermostat might just be the ticket...
Old Jul 9, 2015 | 04:48 PM
rickluc's Avatar
rickluc
Thanks
Old Jul 12, 2015 | 10:28 PM
04DakAz's Avatar
04DakAz
Would it be beneficial to get a new thermostat housing gasket?
Old Jul 13, 2015 | 09:00 AM
pierrejoly's Avatar
pierrejoly
on my 2011, the gasket is built into the housing by an o-ring. it never leaked even with multiple removal and installations.
Not sure if your 04 is built the same way, even though it's the same engine.
Old Jul 13, 2015 | 05:21 PM
04DakAz's Avatar
04DakAz
According to rock auto the 2011 takes the same gasket, FELPRO #35692
Was only asking cause im about to replace both hoses and thermostat. For $1.70 im just gonna do it. Thanks!
Old Jul 14, 2015 | 02:36 PM
HammerZ71's Avatar
HammerZ71
Yeah, I'd replace the gasket any time I replace a thermostat...
