Acceleration problems
Old May 23, 2018 | 01:32 AM
daktwos's Avatar
daktwos
Originally Posted by Charlie Rogan
try ur fuel pump I had a 98 Ford f150 and it had the same problem now I own a 03 ram 1500 having the same problem the fuel pump might of got bad gas and can make it run funny with no codes errors trying getting a new fuel pump
You should try posting your issue in the Ram section.This thread is 3 yrs old.Your issue may very well be a plugged egr valve,worth a look for only a gasket.
Old Apr 30, 2019 | 04:36 PM
mcrumel's Avatar
mcrumel
I had the same issue with my 99 xtra cab 4x4. I found one of my front brake callipers sticking. I pulled it apart and checked the caliper piston and it was ok. Next I cleaned the caliper slides with a wire brush then applied grrease. Problem went away and it has ben months since I did the repair
