Shaky Truck
Old Sep 1, 2015 | 11:45 AM
dakotaff's Avatar
dakotaff
HERE is the whole TSB for the brake shuddering issue.
Old Sep 1, 2015 | 11:52 AM
^^Awesome!
Old Sep 1, 2015 | 04:49 PM
h2ogunr's Avatar
h2ogunr
my truck does this but oddly my rear axle isnt the one under the tsb.i have a v8 the one in the tsb covers is generally installed in v6 models. probably another case of a manufacture trying to duck dive and dodge (lol) a problem they know exists. once a enough people die in accidents they will get sued by dewey takem and how. the lawyers will get rich and the folks get ten bucks.
Old Sep 1, 2015 | 09:56 PM
Don't know of anyone who has died yet from a shaky brake.
Old Sep 6, 2015 | 08:29 PM
baross1's Avatar
baross1
I posted a few months back, my '06 had the same problem. After replacing front pads and rotors, still there. Replaced rear brakes, still there. Bought new drums at Auto Zone, still there.
Took it to my boss's mechanic. He took me for a ride and used the emergency brake to stop us while holding the brake release. That pin pointed the problem to the rear brakes. He turned the new drums( which were about the worst he had seen), and the problem was gone.
Old Sep 8, 2015 | 06:50 AM
sdsdsd's Avatar
sdsdsd
Trucks have too many problems this should be covered by Dodge !!!
Old Sep 9, 2015 | 04:18 PM
h2ogunr's Avatar
h2ogunr
some are determined to worship the throne that dodge sits upon, im not one of those guys. a spade is a spade.
the problem will go away after you turn the drums but trust me it will be back. you can find old threads here that say the same.
i still think something is up with the rear brakes and axles. there are two different spring kits for the rear brakes, some improved set and the standard set. yet getting the improved set of brakes shoes proved for me futile.
the holes need to be in different places for the new set of springs.
worship the dodge brothers all you like i would to if they would just come clean and tell what the problem is so i can fix it.
i believe the corporate axle is jacked up like the other one and its aggravated somehow by the brakes. slop in the bearings or races or bent axles, perhaps improperly balanced axles. i dont know but ill bet dodge does.
oh all the car companies are the same though so lube up.
Old Oct 26, 2015 | 03:55 PM
Mark2002's Avatar
Mark2002
I just started getting the braking vibration in my 2007 with 73k miles. I replaced the front pads and rotors about 16k miles ago before I started getting the vibration, so I thought the rotors went bad already. Rear shoes were low so I did them last weekend, but the drums looked fine. I will turn them and see what happens. It feels like it is in the front, but I will give it the e-brake test to see if I can isolate it. Not much meat on the stock rotors or drums from the factory (hopefully I can turn them)
Old Dec 21, 2016 | 09:59 PM
209dave's Avatar
209dave
Default how much?
How much was it to turn the drums, approx?
Old Dec 22, 2016 | 01:37 PM
Jaded's Avatar
Jaded
Been quite a few years back that I checked into this - was for another vehicle, not the Dakota. but the auto parts store near me wanted $20 per drum. That seemed expensive so I just bought new ones instead.
