2007 dodge dakota power steering leak
Old Dec 22, 2015 | 01:09 PM
dodgedakotadude's Avatar
dodgedakotadude
Default 2007 dodge dakota power steering leak
Hi I have tried everything with my pump. I have taken it to my local shop and they have replaced the pump itself 3 times but it still leaks. It seems to be leaking from the pressure lines. Would it be better to take off the whole pump and reevaluate the situation or is there any way I can trouble shoot it differently to find out what the underlying problem is?
Thanks in advance! Sorry if I posted this in the wrong forum, mods!
Old Dec 22, 2015 | 01:10 PM
What's leaking? The pump or the hoses? If it's leaking from the hoses, replacing the pump won't help. Replace the hoses.
Old Dec 22, 2015 | 02:41 PM
mxjd619's Avatar
mxjd619
Are you 100% its leaking from the pump? I just replaced my rack a cpl weeks ago because it was leaking outta the seal. If its a big leak you should see it right away. Spray it down underneath with degreaser, that might help locate the leak better instead of throwing money at it.
