Code PO159 - HELP
Old May 15, 2017 | 03:22 PM
redbirdfaninkc's Avatar
redbirdfaninkc
Default Code PO159 - HELP
2011 Dakota Big Horn, 3.7L V6
CEL light continues to come on.
I have replaced the O2 sensor that is on the passenger side and downstream of the catalytic converter. Reset code, and it came on shortly thereafter.
I have done the best I can to check for vacuum, and exhaust leaks. Nothing jumping out at me.
All wiring to O2 sensor looks good. No damage.
If I reset the code, it will stay off until I drive at highway speed for 3-5 miles. As soon as I let my foot off the accelerator to exit the highway the CEL comes back on.
I have also reset the computer to rule out it throwing a stored code.
I am at my wits end with this and I am looking for any ideas I can get.
I have even taken it to a Dodge dealership and they tell me they can't even fix it. This all occurred when the vehicle still had a warranty on it. Pretty sure all they ever did was reset the CEL.
Please help!
Thank you.
Old May 15, 2017 | 10:42 PM
Jaded's Avatar
Jaded
When I look this up - possible causes.
*Oxygen sensor defective
*systems running very rich or lean
*engine misfire
*fuel pressure very high or low
Maybe there's a rich or lean condition happening when you let off the pedal.
Old May 24, 2017 | 01:13 AM
fcastro's Avatar
fcastro
How about back to the basics, have you checked for vacuum leaks?
Old May 31, 2017 | 12:25 PM
redbirdfaninkc
Default vacuum leaks
fcastro, I am no expert mechanic....how does one check for vacuum leaks?
Old Jun 8, 2017 | 02:50 PM
WvChamp's Avatar
WvChamp
Hey redbird,
Here is a little information for you to test/diagnose with. Hope it helps.
http://dh.identifix.com/AssetDetails...tStructureId=1
Old Jun 8, 2017 | 04:55 PM
redbirdfaninkc
Originally Posted by WvChamp
Hey redbird,
Looks like that is a service you have to pay for? Not sure if you are a salesman for them, or if I am missing something???
Old Jun 13, 2017 | 11:12 AM
WvChamp's Avatar
WvChamp
Lets try it this way...Sorry.
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
