2006 dakota TCM
Old Sep 25, 2017 | 06:57 PM
2006dakota47's Avatar
2006dakota47
Default 2006 dakota TCM
get code p0700 and others at times referring to TCM. When I look for a replacement TCM I can not find one for the 2006 model year. Is there a TCM or is there a different name or is it combined in another part such as ecu.
Old Sep 25, 2017 | 07:05 PM
Chrisj0424's Avatar
Chrisj0424
The TCM is an all combined part in the 2006 I just replaced mine with the same error code you want to purchase the ECM. I replaced mine about a month ago thinking that had to be the problem after I already replaced the transmission bit that didn't fix it either. I'm thinking my next step is to replace the wiring harness that's the only other thing it can be. So with that being said good luck to you
Old Sep 25, 2017 | 10:11 PM
2006dakota47
thank you
