Transmission cooler install DIY
Old Oct 8, 2018 | 08:58 PM
infamousjim's Avatar
infamousjim
Originally Posted by regg187
IDK on the 4.7 I did mine on the 3.7 6 cyl. but yes I cut the passenger side of the radiator. if your not sure. drive it into the dirt, pull the fitting out of the radiator and turn it on and pit it in drive just for a sec. if fluid shoots out the rad your OK. If it shoots out the hose then that the wrong side. dirty but works
I was thinking of that but also nots sure I want to get that level of dirty. All the completed pics I'm seeing seem to be pass side, I assume v6 or v8 they're close enough in overall design. I'm willing to roll the dice. Thanks!
