Heater control stuck on high
Hello, My heater **** is stuck in the high position. When you want a little fan forced air movement on a warm day from the dash vents, it is all the way to the warm(RED) setting, also the A/C has been rendered useless. In addition,prior to this problem,when the thermostat **** was moved there was a loud clicking noise reminiscent of a machine gun.
96,000 miles on the clock for my truck at 12 years old. The only thing that I like on this vehicle so far is the 4.7 engine, whick provides a nice amount of giddy-up,especially since I had the local muffler shop put a new magnaflow with a 3" pipe
on it. Lots of little maddening problems with this vehicle that are not acceptable for the mileage. ANYBODY at Dodge listening to this? 2005 Dakota club cab ST w/factory tow package. 4.7L
As a 2ND problem that also recently popped-up, now there is a feeling of driving on a washboard road above 40MPH. 5 spd
auto trans.
Any help on these matters would be appreciated greatly.
Thanks Much,
Rex in Monrovia,Ca.
auto trans.
Thanks Much,
Rex in Monrovia,Ca.
1st problem sounds to me like your Blend Door has a stripped cog where the Actuator Motor mounts. Plastic don't like being moved COLD.
2nd problem (Without more details) is possible a tire out of balance or a belt broke in a tire.
