Intermitent Shutdown 2007 Dakota
Old Jul 25, 2018 | 08:23 AM
McCue's Avatar
McCue
Default Intermitent Shutdown 2007 Dakota
Shutdown occurring on V-6 engine 2007 Dakota 2 wheel Drive. No problems for last two years but then shutdown while driving. Technicians have spent days looking for electrical issue but have not found one. 2 amp fuse was bad but after replacement still shuts down and will not restart. Have removed and cleaned all wiring connectors and no trouble codes appear on computer. Planning to replace ignition switch and other suggested parts if anyone can assist on possible problems.
Old Jul 25, 2018 | 12:28 PM
Verify spark and fuel.
Old Aug 18, 2018 | 02:35 PM
McCue's Avatar
McCue
2007 Dakota Intermittent Shutdown solved. Sequentially Replaced and tested Ignition switch, Computer, Cam Sensor, Crank Sensor, relays in TIPM no change in problem. Could not get new TIPM, so ordered from junk yard. Replaced it and problem resolved. No failure codes were ever indicated. Hope others do not have similar problem but apparently TIPMs are source of many intermittent problems on these trucks/cars.
Old Aug 18, 2018 | 02:37 PM
McCue's Avatar
McCue
Thumbs up
TIPM issues are common sources of intermittent electrical problems.
Old Aug 21, 2018 | 05:11 PM
wankle's Avatar
wankle
what is TIPM ?
Old Aug 21, 2018 | 05:28 PM
Originally Posted by wankle
what is TIPM ?
Totally integrated power module. Think of the TIPM like a command center for all the electrical functions of your car
