Batter Draw CCN Fuse
Old Aug 29, 2018 | 10:42 AM
WickedWrench's Avatar
WickedWrench
Default Batter Draw CCN Fuse
Have a 2006 Dakota 4wd v6 that keeps draining the battery overnight. Swapped battery with another vehicle because I thought the economy battery I installed had dead cell. Battery died again, so I decided to perform a parasitic draw test. Opened all doors and shut latches so I could gain access to interior. waited 10-15 minutes for modules to go to sleep and had a 1.6 amp ignition off battery draw. started pulling fuses and came across fuse #55 CCN accessory feed when I pulled fuse draw went away. put fuse back in draw is back. 1 hour later still had same draw. Pulled up all data schematic and found fuse feeds the cluster but I am feeling that it feeds more. Anyone have a diagram that shows more or have had this issue before? Am I headed in right place with a cluster thanks in advance for any advice on this!
Old Aug 29, 2018 | 11:22 AM
northgator8's Avatar
northgator8
Wiring diagrams should be here:
https://dodgeforum.com/forum/3rd-gen...-and-more.html
Old Aug 29, 2018 | 11:38 AM
northgator8
Old Aug 29, 2018 | 12:32 PM
WickedWrench
Northgator8 thank you for the diagram. by looking at diagram it seems to me the ignition switch feeds fuse 55 and is not powering down on the acc run keeping fuse 55 powered up. I will test it tonight and post details funny though because the cluster seems to shut down.
Old Dec 28, 2019 | 11:44 AM
Jhoone Mateo's Avatar
Jhoone Mateo
I’m not a mechanic but I have the same problem with with my 2006 dodge Dakota, so what correction have you made for your vehicle, right now I just disengage my CCN ACC feed/ fuse
Old Dec 19, 2020 | 08:10 PM
tdoolittle's Avatar
tdoolittle
Did you ever figure this out? I'm having the exact same issue with fuse #55 and can't figure out how to eradicate it. What did you end up doing?
