Gas cap?
Old Sep 30, 2018 | 09:59 PM
baross1's Avatar
baross1
Default Gas cap?
Just looking for info
Check engine light came on a few weeks ago. Not sure what the code was, but mechanic said I need to replace the gas cap. Purchased one and installed. Light came back on yesterday and he said it was the same...bad fuel cap. Any ideas
Old Sep 30, 2018 | 10:16 PM
primem's Avatar
primem
post the code that set, your model year and engine size.
The " checkfuel cap" light/message sets when the evap system detects a large leak after a fueling event...doesn't mean the leak is from the gas cap. testing needs to be done...throwing a fuel cap on it is a shot in the dark. Fuel caps probably fix this 10% of the time.
Old Oct 1, 2018 | 08:38 AM
Post the exact code. If it is a gascap code, 99% of the time, only using an OEM cap purchased from the dealer will cure it.
Old Nov 20, 2018 | 08:46 PM
baross1's Avatar
baross1
Check engine light came on again. Code is P0456...Any ideas?
Old Nov 21, 2018 | 08:00 AM
Yes you will need to get the system smoke tested to find the culprit.
https://www.obd-codes.com/p0456
Old Nov 21, 2018 | 06:27 PM
baross1's Avatar
baross1
Thanks for the link JKeaton. Question....This is a daily driver to work, but not alot of miles. Live 2.5 miles from work. Will this be a problem or do I just have to deal with the check engine light? We do not have emissions in my county
Old Nov 21, 2018 | 06:29 PM
dont think it will be a problem. It’s not like it’s an o2 sensor code that would affect engine operation.
Old Nov 21, 2018 | 10:39 PM
primem's Avatar
primem
once the temps get cold enough the evap monitor won't run.
the code is for a small evap leak. 3rd gens could use 2 different type evap systems...depends on your model year...the systems work different so some of the testing is different.
the first step would be a flow test using a smoke machine.....with a sealed system the flow meter check ball should fall below the allowable flow rate...if it does, there is no leak...the fault could be a issue with the esim.
Old Nov 22, 2018 | 12:24 PM
superdak05's Avatar
superdak05
make sure you purchase a original manufacture gas cap, don't go aftermarket, if light still comes on, fill truck with 92/93 octane and run it for a few miles, preferably highway, being so close to work things might not be getting up to temp and working.
Old Nov 22, 2018 | 08:37 PM
primem's Avatar
primem
how does changing the fuel octane effect the evap system monitor? If its an esim equipped system the passive test runs overnight after the truck is shut down.
