2005 Dodge Dakota Key Sentry problem
Old Oct 16, 2018 | 12:42 PM
Spydie's Avatar
Spydie
Default 2005 Dodge Dakota Key Sentry problem
Okay so got this Dakota from an online retailer back in 2011
Lot's of problems with it but that's beside the point. When I got the truck it only came with 1 transponder key.
I've had issues with it a couple of times (like if I left it in a pants pocket and went through the wash). It would do the old "run for 2 seconds then shutoff and lock you out after a few attempts" Would always start working after I opened transponder up and dried it out.
Well now I went out to start truck after sitting for about 3 months. Started right up but did the die thing after a couple of seconds. At first I thought it was just because it had been sitting so tried a few times...locked out.
So now I sit with a truck that won't start and no working transponder key. Talked to dealer and their only solution is to tow it in and pay them to blah, blah, blah. I really don't want to drop $500 or more on this seldom used truck.
Any ideas out there??? There has got to be some way to disable this security feature!!!
Thanks in advance
Old Oct 16, 2018 | 12:53 PM
northgator8's Avatar
northgator8
If there was a way to disable this "security feature" it wouldn't be a "security feature". You need the proper code reader/dealer computer. Some locksmiths have the codes as do some independent service centres and some aftermarket sellers of remotes.
Old Oct 16, 2018 | 12:56 PM
Dealer or locksmith are really your only 2 choices.
