Overhead Console Battery Drain Issue on an 07 SLT
Old Jan 23, 2019 | 12:15 AM
Shirebikes's Avatar
Shirebikes
Default Overhead Console Battery Drain Issue on an 07 SLT
Hi All,
I've got a 4.7 Flex SLT, with the overhead console with the compass and mpg gauge which works all fine, however when its connected i have a battery drain - i realise i probably just need to replace the module, but i thought i would see if anyone else had come across this problem and had managed to fix it.
thanks
Old Jan 26, 2019 | 07:05 PM
dakotaff's Avatar
dakotaff
How did you determined the console was causing the drain?
Have you disconnected it to see if that is really the cause?
Welcome aboard.
Old Jan 26, 2019 | 07:50 PM
Shirebikes's Avatar
Shirebikes
Hi, thanks for the reply. It's 100% the cause, no drain issue with it disconnected... I ended up ordering a second hand unit so will see if that works!
