Which Engine do I have?
Hi all - brand new Dakota owner here. Just purchased an '06 quad cab, V8, 4wd Laramie with 104k miles on it. Had been looking for a long time, glad to finally get one.
How can I tell which of the engines I have? There seems to be a "J 4.7L FI SOHC HO" and an "N 4.7L FI." I'm not the most well-versed home mechanic type, so I'm not sure what the difference is (although I know SOHC = Single Overhead Cam, right?), nor what sorts of parts purchases will be affected, but it seems like something I should know for future reference. And a related question would be (since I was looking for brake pads) how can I tell if I have 2 wheel ABS or 4 wheel ABS? Thanks so much, and I'm looking forward to being a part of this community! |
Engine code is the 8th number in the VIN. "N" is the normal 4.7L Magnum. "J" is the high output version. IIRC all Dakotas have 2 wheel ABS. You can request a build sheet that will tell you all the various options and available equipment your truck came with from the factory.
https://www.dodge.com/webselfservice...ull&category=U Fill out all the required information, then in the area that says "What can we help you with" put "Vehicle Build Sheet" . If you want to elaborate a little more as to why you want your build sheet, use the description area. They normally respond within a few days Welcome to the forum. |
