2nd gen to 3rd gen front end swap.
Old Jul 10, 2019 | 04:39 PM
Sirlucious's Avatar
Sirlucious
Default 2nd gen to 3rd gen front end swap.
So I have a friend with a 2005 dakota that blew the front carrier. It is 3.55 and a 4.7.
I have a 2000 dakota that has a good complete front end in it and was also a 4.7 with 3.55. What I've found online is that only 01 an up dakota and 01-03 Durango front ends will work not the 2000 and earlier. It seems like the same axle and chassis so what am I missing!? Is one just aluminum housing and earlier is cast? Thank you just try to save them some money.
Old Aug 9, 2019 | 11:41 AM
David Kalinowski's Avatar
David Kalinowski
the 3rd gen from what I have gathered was a completely new frame from the ground up. I don't believe there is much if any part interchangeability between 2nd and 3rd gen. I could be wrong. I notice this almost a month old and your friend may have (probably) already fixed the issue, but maybe some one will chime in for future reference.
Old Aug 19, 2019 | 06:06 PM
stetson's Avatar
stetson
The front diff doesn't bolt to the frame iirc. It attaches to the motor mounts and the bell housing.
As far as i know they can be swapped in.
