stalls when in reverse and drive
truck will run fine when in park around 700 rpm's when I put in reverse or drive the rpm's will drop and wants to stall, I cleaned the mass airflow sensor double checked all the connections, but still having the same problem. should i take to local auto parts store and have them check
thx
thx
Does the truck "jerk" when you put it in gear? Mine did that and it turned out to be a transmission problem. The lockup clutch in the torque converter started disintegrating and contaminated the fluid. It would allow for the pressure release and would act like I was putting a manual transmission in gear without using the clutch. If I came to a quick stock it would act like I was stopping a manual truck in gear without releasing the clutch.
