'05 Dakota 2WD wheel bearing and hub torque specs.
Old Feb 19, 2020 | 10:23 AM
Caulin Sheridan's Avatar
Caulin Sheridan
Default '05 Dakota 2WD wheel bearing and hub torque specs.
I've been rummaging through Google and all I find are the torque specs for the 4x4 version, which I've noticed have been different than the 2wd version in older model years of the truck. It's typically lower as far as I've seen, I'm assuming because it also has the drive bolt holding it too. Does anyone know the torque specs for the front bearing and hub assembly of a 2 wheel drive 2005 Dakota? I don't have an air impact, but I do have a 300lb torque wrench, so "tight as hell" isn't really an option.
Old Feb 19, 2020 | 12:00 PM
dakotaff's Avatar
dakotaff
There is no difference, you can download the 2005 Dakota Factory Service Manual from Here.
