Rear Differential Drain and fill service
Old May 3, 2020 | 11:59 AM
3rdgenHighoutputDakota's Avatar
Default Rear Differential Drain and fill service
Good Morning,
I am needing to perform the rear differential service on my 2005 dakota 4.7 . Just wanting some general information as to how to tell whether my diff is 8 1/4 or 9 1/4. And also how to figure out the capacities and whether or not I need a no slip additive. I have access to All Data at the Dealership I work at and It says that if my diff is equipped with trac lock I need the additive. Thanks in advance for the help...
Old May 3, 2020 | 07:54 PM
philipat's Avatar
philipat
If you get your build sheet, it will tell you what size your differential is and whether you have a limited slip differential.
Build sheet: https://fcacommunity.force.com/RAM/s/equipment-listing
You'll need to enter your VIN.
Old May 3, 2020 | 09:01 PM
Thanks
Old May 3, 2020 | 11:00 PM
dakotaff's Avatar
dakotaff
Look at the rear diff:
8.25 = 70 ounces.
9.25 = 72 ounces.
