2006 Dakota. V6 extra cab
A long road to fixing an EVAP solenoid check engine issue (computer, EVAP solenoid, and throttle body) but I finally arrived and it was time to get a smog cert.
Took it to a reputable shop and Initially the truck failed. I hadn't driven the truck very far given the plates were out of date. So the shop then puts the tuck on a dyno and exercises it for a hour or two while charging me for 'discounted' tech time. In the end it passed but the claim from the shop was that it was tricky to dial it in.
So is this just that I could have saved the tech time and driven the truck around to condition all the emissions related sensors and it would have passed with standard shop effort?
Or is it truly something about this truck that requires some adjustments to be made while testing it to yield a passing result (maybe something that needed to be set in the new computer)?
I know my truck takes a long damn time to set the O2 and Cat Sensors into a 'Ready' status. Those two sensors need to pass their checks to get 'Ready', and there are specific driving conditions that need to happen before that occurs, called a Drive Cycle. I have to return my truck to 'Stock' (My truck is tuned with a SC3865 programmer) months before inspection so I can pass inspection here in NJ. It's a mystery of the exact conditions necessary, I've found a few different Drive Cycle procedures for Dodge Dakotas.
You have to drive at least 150 miles, (not at once), consisting of both highway and city driving. Do some gradual acceleration, hold it steady at 55-60 mph for a while, and decelerate by letting off of the gas petal coasting to slower speeds. Pretty much just some casual driving and you'll pass the inspection.
If you disconnect your battery, give it a tune with a programmer, or have the dealer flash your PCM, you'll have to put all of those miles back on again. The longer that you drive, and put miles on your truck, the better chance that your sensors will be in a 'ready' state.
You could have drove it. You also could have been pulled over, then they usually find something else you're doing wrong making the fees paid to the shop rather inexpensive.
This Dodge Drive Cycle was posted elsewhere, not sure if this exact process will actually get those sensors Ready.
How to Perform a Dodge Dakota Drive Cycle
Replacing the battery or having simply disconnected the battery on your Dodge Dakota caused the engine control unit (ECU) to reset and clear all the emission monitors (and trouble codes; if any existed).
We're going to recommend following the Dodge Dakota drive cycle we indicate below. It should get the catalyst monitor, as well as the EGR, EVAP and AIR monitors, ready for the smog inspection. If you've tried the drive cycle already and have still been unable to get all the monitors complete, we'll have to recommend a smog check repair station or Dodge dealer take a closer look. Even though the check engine light is no longer illuminated, there may be a sensor which is partially failing and stopping the catalyst monitor from becoming Ready or Complete.
Typically driving 200-300 miles through various traffic conditions and over the course of a few days is enough to get the drive cycle to initiate. Simply driving an extend length of time however does not necessarily make the monitors complete. Your Dakota's engine control unit performs internal self-tests in order to ensure the engine is running efficiently and not polluting. These self-tests are called Monitors. The entire process of self-testing various emission control systems is called a Drive Cycle. Notice: Obey all traffic laws while performing drive cycles. Perform the drive cycle cautiously and at your own risk. Use a OBD-II scan tool to check the status of the monitors once you've completed the drive cycle at least once.
How To Perform Dodge Dakota Drive Cycle A. All Monitor Drive Trace - This will complete all emission monitors without having to perform specific monitor driving patterns.
Pre-Conditioning Requirements:
MIL must be off - Cold start (Cold soak required; vehicle must be sitting overnight, at least 8 hours).
Driving Procedure:
1) Warm engine up for five minutes (must reach closed loop)
2) Drive (with steady throttle) at a speed between 40 and 60 mph for 8 minutes.
3) Stop and idle for 3 minutes.
4) Drive (with steady throttle) at a speed above 20 mph for 2 minutes.
5) Turn key off, leave off for ten minutes (to run O2 sensor heater monitor).
Note: Due to the limited preconditions provided with this drive trace, NCVECS recommends using the monitor specific drive traces for Dodge Dakota vehicles.
B. Catalyst Monitor Drive Trace
- MIL must be off.
- No DTCs present.
- Fuel level is between 15% and 85% full.
- ECT above 70º F.
- Engine must have run at least 90 seconds
- Engine between 1,350 & 1,900 rpm.
Driving Procedure:
1) Idle vehicle for five minutes (to reach closed loop operation).
2) Drive with a steady vehicle speed between 30 and 45 mph for 2 minutes.
C. EGR System Monitor Drive Trace - Vacuum controlled
- MIL must be off.
Driving Procedure:
2) Drive with a steady vehicle speed between 40 & 60 mph for 8 minutes.
D. EGR System Monitor Drive Trace - Electronic
- MIL must be off.
- MAP must be between 0-60 KPa.
- Engine speed between 500-850 rpm.
- ECT is above 180º F (90º C).
- No misfire temporary (pending) or matured fault present.
- A/C clutch, PS Switch and Cooling fans do not change state (turn off).
Driving Procedure:
1) Idle vehicle for five (5) minutes (to reach closed loop operation).
2) Drive with a steady vehicle speed between 40 & 60 mph for 2 minutes.
3) Idle vehicle for three (3) minutes.
E. Evaporative System Monitor Drive Trace
Trace 1: Standard Type
- MIL must be off.
- No Evaporative DTCs present.
- Fuel level is between ½ and full.
(Note: monitor may still run with tank fill between 15% and 85%).
Driving Procedure:
Trace 2: With Leak Detection Pump
- MIL must be off.
- Fuel level is between 30 & 85 % full.
Driving Procedure:
1) Cold soak vehicle, start and idle vehicle for 4 minutes.
2) Drive in-town (stop and go) for 5 minutes, using smooth accelerations and decelerations.
3) Stop and idle vehicle for 4 minutes.
F. O2 Sensor Monitor Drive Trace
- MIL must be off.
Driving Procedure:
2) Drive with a steady vehicle speed above 25 mph for 2 minutes.
3) Stop and idle for 30 seconds.
4) Smoothly accelerate to a speed between 30 and 40 mph.
5) Repeat steps 3 & 4 five (5) times.
G. O2 Sensor Heater Monitor Drive Trace
- MIL must be off.
Driving Procedure:
2) Shut engine off and leave vehicle off for ten minutes.
I use the Elm /obd2 tester with a app on phone .It tells you when each monitor is ready.
It also shows current readings as running an codes,other tests,clearing codes,etc..
That way I'm sure it's ready after driving.
Agreed. Just walking into a $40 smog cert and walking out with a $200+ bill was pretty disappointing. Not really blaming the shop but this whole scenario is a catch22 load of BS.
