AlfaOBD scan of BCM
Old Mar 8, 2021 | 10:26 AM
EVguy's Avatar
EVguy
Default AlfaOBD scan of BCM
I have a 2008 quad cab 4X4 with a Cummins ISB170 and NV4500. Looking for someone to upload their BCM config file from AlfaOBD. I fried mine and have a used one but need the configuration. Sure appreciate a response.
Should look something like this.
Config Summary 2:
FCM Programmed Status: Yes
Last Programmed: Service
Wheel Speed Sensor: Set
Brake Fluid Level Sensor: Set
Battery Temp Sensor: Not Set
Hazard Switch: Not Set
Horn Chirp Allowed: Not Set
Transmission Feed Control: Not Set
Tcase Type: 244 (Digital)
Reconfig Input #1 (24/14): Not Present
Reconfig Input #2 (24/23): Not Present
Reconfig Input #3 (49/40): Not Present
Reconfig Input #4: Not Present
Front Fog Lamps: Not Set
Ignition RUN/ACC and SPAD: Not Set
Ignition RUN/ACC and PAD: Not Set
Adjustable Pedals: Not Set
Power Inverter: Not Set
Reconfig Output #1 (49/10): Not Present
Reconfig Output #2 (49/21): Not Present
Reconfig Output #3 (49/22): Not Present
Reconfig Output #4 (49/28): Not Present
Reconfig Output #5 (49/45): Not Present
Reconfig Output #6 (49/49): Not Present
Reconfig Output #7 (49/14): Not Present
Reconfig Output #8 (49/16): Not Present
Reconfig Output #9 (49/13): Unlock/Run/Start
Reconfig Output #10 (49/39): Not Present
Reconfig Output #11 (24/04): Start (Remote Start)
Reconfig Output #12 (49/16): Run (Remote Start)
Quad Headlamps Enable: Not Set
HID Enable: Not Set
DRL Enable: Not Set
DRL Dropout Enable: Not Set
DRL Europe Enable: Not Set
Park Lamp Loadshed Enable: Not Set
Front Fog Lamp Dropout Enable: Not Set
Combined Rear Lighting Enable: Not Set
Auto Headlamp Enable: Set
One Touch Lane Change: Set
Exterior Light Loadshed Enable: Not Set
Front Wiper Park Enable: Not Set
Rear Wiper Park Enable: Not Set
Reversible Washer Pump Enable: Not Set
Right Low Beam Voltage Regulation: 13.2 V
Right High Beam Voltage Regulation: 13.2 V
Left Low Beam Voltage Regulation: 13.2 V
Left High Beam Voltage Regulation: 12.6 V
Left DRL Voltage Regulation: 6.60 Volts
Right DRL Voltage Regulation: 6.60 Volts
DRL Configuration: No DRL
DRL Lamp Location: High Beam DRL
AHBM: Not Set
AMP: Not Set
CCN: Set
DDM: Not Set
VES3: Not Set
SDARV: Not Set
BSM: Not Set
EOM: Not Set
HFM: Not Set
HSM: Not Set
HSTW: Not Set
HVAC: Set
ITM: Not Set
LRDM: Not Set
LRSM: Not Set
MSMD: Not Set
OCM: Not Set
ORC: Not Set
PDM: Not Set
PTS: Not Set
Radio: Set
RRDM: Not Set
SCM/SCM (CAN-B): Not Set
SDAR: Not Set
AHLM/HIDT: Not Set
SUNR: Not Set
WCM: Set
VES: Not Set
DISP: Not Set
NAV: Not Set
PLGM: Not Set
PASS: Not Set
PEM: Not Set
PTCM: Not Set
TM: Not Set
TMC/TMM: Not Set
PTIM: Not Set
ABS: Not Set
PCM: Set
TCM: Not Set
ORC/ ORC (CAN-C): Set
WCM/WCM (CAN-C): Set
FDCM: Not Set
ESM: Not Set
SCM (CAN-C): Not Set
SUSP: Not Set
HGM: Not Set
ISG: Not Set
PEM: Not Set
EAC: Not Set
OCM: Not Set
ACC: Not Set
EPS: Not Set
APM: Not Set
TCM: Not Set
BPCM: Not Set
HCP: Not Set
MCPA: Not Set
MCPB: Not Set
Vehicle Configuration Data:
____________________________________
Autostick Transmission: Not Set
Tip Start Present: Not Set
Diesel Regeneration Present: Not Set
Hybrid Electric Powertrain: Not Set
Cruise Feature Present: Not Set
ABS Present: Set
ASR Present: Not Set
ESP Present: Not Set
BAS Present: Not Set
Full Size Spare: Not Set
Remote Start Present: Not Set
Aisin Transmission: Not Set
Heated Seats Present: Set
Off Road Capable: Set
Vehicle Line: 3H
Left/Right Hand Drive: Left Hand Drive
Model Year: 2008.00
Body Style: 4-Door Pickup
Country Code: Canada
Drive Configuration: Selectable 4wd
Fuel Capacity: 83.00 Liters
Wheel Base: Not Programmed
Radio Market Select: North America
DVD Region Code: 1
Special Marketing Package: None
Tire Pressure System Present: Set
Compass Temp. Display Present: Not Set
RKE System Present: Not Set
SKIM System Present: Not Set
Automatic Temperature Control HVAC: Set
Remote Steering Wheel Switches: Set
Power Driver Seat: Not Set
Power Passenger Seat: Not Set
Power Folding Mirror: Not Set
Heated Mirrors: Not Set
Flipper Glass Present: Not Set
Power Lift Gate Present: Not Set
Power Left Sliding Door Present: Not Set
Power Right Sliding Door Present: Not Set
Police Lighting Feature: Not Set
Switches are Dimmable: Not Set
Disable CD Eject: Not Set
Disable Display of Clock Radio: Not Set
Tilt and Telescopic Steering Control Column: Not Set
Mirrors Contain Signal Lamps: Not Set
Windows Perform Door Vent: Set
Windows Perform Convertible Vent: Not Set
Mirror Switch Attached to Door Module: Not Set
Navigation System Present: Not Set
Central Locking Configuration: Both Central Locking
Door Lamp Configuration: Not defined
Window Express Feature Configuration: Driver Only
Memory Switch Configuration: Not defined
Interior Vehicle Theft Alarm Configuration: Not defined
Security Switch Type: Not defined
Cabin Equalization Curve Number: 255.00
Side Airbag(s) Present: Not Set
Pass Airbag Disable Switch Present: Not Set
TPM Premium: Not Set
Reverse Chime: Not Set
Smart Feature Present: Not Set
Two Fuel Sending Units Present: Not Set
Front Park Assist Present: Not Set
Rear Fog Lamps Present: Not Set
Compass Mounting Angle: 0.00 Deg.
Compass Mounting Orintation: Rightside up
A/C Present: Set
Rear Camera Present: Not Set
Axle Ratio: 3.55
T-Case High Ratio: 1.00
T-Case Low Ratio: 2.72
Tire Circumference: 2600.00 mm
Brake Type Calibration: Type 0
Suspension Type: Not Programmed
Front Tone Wheel Teeth: 48.00
Rear Tone Wheel Teeth: 108.00
Maximum Vehicle Speed: 255.00 km/h
Brake Type Modifier for Calibration: Set
NTG4 Radio Present: Set
UDGO Feature Present: Not Set
EVIC Reconfigurable Display Present: Not Set
Weight Sensing System Present: Not Set
Cargo Lamp Present: Set
Rain Sensor Present: Not Set
Rear Heated Seats: Not Set
Front Tire Circumference (Alternate): 0.00 mm
Convertible Type: Not a Convertible
Power Inverter Type: None
Vehicle Brand: Dodge
Occupant Detection Sensor Present: Not Present
WIN Module Present on CAN-C: Not Present
Vehicle Equipped with Optional Side Airbag: Vehicle not Configured for the Optional SAB
Driver Seat Track Position Sensor Present: Not Set
Passenger Seat Track Position Sensor Present: Not Set
RCD Performance Option: Not Set
EBC Function 0: Not Set
EBC Function 1: Not Set
EBC Function 2: Not Set
EBC Function 3: Not Set
EBC Function 4: Not Set
EBC Function 5: Not Set
EBC Function 6: Not Set
EBC Function 7: Not Set
Front Tire Placard Press (Lgt Ld): 35.00 PSI
Front Tire Placard Press (Hvy Ld): 35.00 PSI
Rear Tire Placard Press (Lgt Ld): 35.00 PSI
Rear Tire Placard Press (Hvy Ld): 35.00 PSI
